Sending data using zero-copy
  • Sending data using zero-copy
    Hi all,
    does anyone have experience sending data using zero-copy, especially with TCP?
    With the code below I am experiencing system-lockups (either in HardError-handler or an endless-loop somewhere in the IP-stack) after 5 to 30 seconds.
    Until then, the performance is awesome :)
    What is wrong with my code? Any working example, or link to some documentation?
    Stefan
    1. while(1)
    2. {
    3. IP_PACKET * pPacket;
    4. U32 bytes = 512;
    5. do
    6. {
    7. pPacket = IP_TCP_Alloc(bytes);
    8. } while(pPacket == NULL);
    9. /* memset(pPacket->pData, '.', bytes); */
    10. int iSend = 0;
    11. do
    12. {
    13. iSend = IP_TCP_Send(fd, pPacket);
    14. } while(iSend < 0);
    15. }
    The post was edited 1 time, last by stefan.waldschmidt ().
  • Some reasons for the problems
    To follow up on my own post:
    One major reason for my problems was probably the lack of network buffers:
    After all available buffers are in use by low-priority tasks, the high-priority zero-copy task endlessly loops in
    1. do
    2. {
    3. pPacket = IP_TCP_Alloc(bytes);
    4. } while(pPacket == NULL);
    Increasing the number of configured buffers and adding a sleep() helped a lot.
    Still, I would love to see some working examples and/or documentation.
    Some other improvements were made to my code, here is the complete version. Any comments?
    Stefan
    1. while(1) {
    2. IP_PACKET * pPacket;
    3. U32 bytes = 512;
    4. do {
    5. pPacket = IP_TCP_Alloc(bytes);
    6. if (pPacket == NULL) {
    7. /* If this happens, increase the number of buffers! */
    8. OS_Delay(1);
    9. }
    10. } while(pPacket == NULL);
    11. /* fillData(pPacket->pData, bytes); */
    12. int iSend = 0;
    13. do {
    14. iSend = IP_TCP_Send(client->fd, pPacket);
    15. if(iSend == IP_ERR_RESOURCE) {
    16. /* No free space in socket's TX-buffer */
    17. /* This OS_Delay is critical;
    18. * for resposiveness of low-priority tasks and throughput */
    19. OS_Delay(1);
    20. }
    21. } while(iSend == IP_ERR_RESOURCE);
    22. if(iSend != 0) {
    23. IP_TCP_Free(pPacket);
    24. break;
    25. }
    26. } /* while(1) */
  • Hello Stefan,
    Thank you for your report and the mail sent to the support address.
    As you already know by mail the problem with TCP zero copy has been found and will be officially fixed in the next release.
    Oliver
