If I create an EDIT widget and set float mode using:
EDIT_SetFloatMode(hObj, 0.0, -1000.0, 1000.0, 0, GUI_EDIT_SIGNED | GUI_EDIT_SUPPRESS_LEADING_ZEROES);
Then the EDIT box is empty. This only occurs if the Value is zero, Shift is zero and both GUI_EDIT_SIGNED and GUI_EDIT_SUPPRESS_LEADING_ZEROES flags are set. If either flag is not set or the Shift parameter is greater than zero, then a value is seen in the EDIT box.
Can this be fixed?
Craig
Can this be fixed?
Craig
