How TO programe BLANK flash CHIP?
  • How TO programe BLANK flash CHIP?
    now have a problem,I erase and program one arm9 bload(have full flash contain bootloader) very good.
    but when I erase entire chip,it can't read erase and program flash.
    what should I to do? how to program blank chip?
    thank you.
  • Hello 56888,
    I am not sure if I understand you correctly.
    What exactly is the problem:
    Do you have problems when programming the flash memory if it is blank?
    Can you program it one time and then can not erase & program it again?
    Moreover, a bit more information about your working environment would be useful:
    1. Which target CPU/MCU do you use?
    2. Do you try to program internal or external flash? (If external: Flash manufacturer, flash description)
    3. I assume you are working with J-Flash, right?
    4. Which J-Flash software version do you use?
