[Solved][GDB-Server] flash-download: Reply contains invalid hex digit 116
  • [Solved][GDB-Server] flash-download: Reply contains invalid hex digit 116
    often while flashing an LPC2368 I receive an error message from gdb:
    1. Transfer rate: 3071 KB/sec, 3773 bytes/write.
    2. Ignoring packet error, continuing...
    3. C:\workspace\Openkeyer_v2\openkeyer\armkeyer_v3/flash.gdb:27: Error in sourced c
    4. ommand file:
    5. Reply contains invalid hex digit 116
    Sometimes it is possible to reconnect to the core using the 'target remote' command, sometimes not. If not I get the following message:
    1. Remote communication error: No error.
    The log output from GDB-Server is:
    2. Downloading 4096 bytes @ address 0x0000BFA0
    3. Downloading 2664 bytes @ address 0x0000CFA0
    4. Downloading 792 bytes @ address 0x0000DA08
    5. Resetting target
    6. Debugger terminated connection ! // <-- "Reply contains invalid hex digit 116"
    7. Connected to 127.0.0.1
    8. Debugger terminated connection ! // <-- "target remote..."
    This is the flash script:
    1. # File to flash
    2. file armkeyer_v3.elf
    3. # Connect to GDB Server
    4. target remote localhost:2331
    5. # Flash configuration
    6. monitor flash device = LPC2368
    7. monitor flash download = 1
    8. # Set speed to maximum
    9. monitor speed auto
    10. # GDB Server defaults to big endian
    11. monitor endian little
    12. # Reset device
    13. monitor reset 0
    14. # Remap first 64 bytes to flash
    15. monitor long 0xE01FC040 = 1
    16. # Flash device
    17. load
    18. # Run
    19. monitor reset
    20. monitor go
    The JTAG-Speed does not affect this behaviour. I am using arm-elf-gdb v6.8.50 and arm-eabi-gdb v6.8 from Yagarto and tried GDB-Server v3.90d and v3.94.
    I am using the ARM board for about one year now and it used to work with j-Link and flash-download.
    Debugging works more often than not. Sometimes the program on the controller does not start after issuing the 'continue' command and the GDB-Server looses the connection to gdb. After a power-cycle of the ARM-board and reflashing the controller it will most likely work. Once the 'continue' command succeeded the debugging session is stable.
    Does anyone have any ideas?
    Thank you
    - Michael Geselbracht
    The post was edited 1 time, last by let ().
  • It seems to be a problem with the newer GDB-Server versions. I have downgraded to v3.82 and everything seems to work.
    There is still the message 'ignoring packet error' but apparently it does not harm.
