Hello ,
I have a problem with button function on my card. I can use emWin library to display text, but I cannot display button. In place of button, there is a black block. As shown in the attached.
Code:
hButton = BUTTON_Create(110, 110, 200,100, GUI_ID_OK, WM_CF_SHOW);
Important: I have made my PCB using stm32f429ii as the LCD controller, a LCD 7’’ screen with 800*480pixels and a 256Mbits SDRAM for memory.
With the same LCD screen in the Discovery kit STM32F42x9I-Eval it works, but not with my card. In my card the button doesn’t appear. Meanwhile, I can display text, images. But I can’t display all the widgets.
Differences between the Discovery kit and my electronic board are the memory SDRAM and microcontroller.SDRAM seems to work well because I can write/read this SDRAM, and performed memory test.
I can't envisage other problem than SDRAM. What other reasons that the button cannot display normally?
Thank you!
Code:
Thank you!
