Font spacing between characters
  • Font spacing between characters
    Hi
    We got our design team to add extra space between the characters of the font (side bearing I believe is the term) but when I generated the font data file, there was no difference in any numbers. Does emwin's font converter not abide by or use the font spacing information? I have v16
    Thanks!
  • Okay I noticed that if I add the space in the font tool using insert column then it does show up in the data. Adding it per character is a pain though so what should we change in the original ttf to ensure that this is processed by emwin's font converter. Perhaps there is something else other than right side bearing that will have the intended effect?
    Thanks!
