I have a Phytec LPC3180 board that came with both IAR and the Linux BSP.
I followed the instructions in the Linux quickstart quide.
The first step of loading bootflash.bin is supposed to be followed by a menu appearing in the terminal menu, but it doesn't happen.
Examining my Jlink output and that show in the quickstart guide shows a few differences e.g. the info line after the line
Reset Type Normal
Info: J-Link: ARM9 ....
does not appear
Neither does the line "Info: Resetting target using RESET pin" appear.
I examined memory at address 0x08000000 and it is the same as the contents of bootflash.bin
I manually executed the commands from the load_bootflash.jlink script but still nothing appears on the terminal screen.
Executing jlink.exe without parameters shows the serial number of the jlink and the ARM core id, so in theory the j-link is working OK.
This has got me tearing my hair out (or it would if I had any).
Insight and help gratefully appreciated.
Reset Type Normal
does not appear
