No boot after programming STM32 with JFlash
  • No boot after programming STM32 with JFlash
    Hi guys,
    I'm using JFlashARM.exe in command line with these options :
    1. JFlashARM.exe -openprj"****.jflash" -unsecurechip -open"****\firmware.bin",0x8000000 -auto -disconnect -exit
    The programming is OK, but the STM32F407VE never boot after that. JFlash say that the application is started. I must unpower and power again to start the board.
    I have the same problem with STM32F103VE.
    I'm using the latest version of JFlashARM (4.80) and JLink v8.0
    The project file is attached and here is the log from JFlashARM:
    Connecting ...
    - J-Link firmware: V1.20 (J-Link ARM V8 compiled Nov 25 2013 19:20:08)
    - JTAG speed: 4000 kHz (Fixed)
    - Initializing CPU core (Init sequence) ...
    - Executing Reset (0, 0 ms)
    - Initialized successfully
    - Connected successfully
    Auto programming target (195504 bytes, 1 range) ...
    - Unsecure chip ...
    - Disconnecting ...
    - Disconnected
    - Chip unsecured successfully
    - Erasing affected sectors ...
    - Connecting ...
    - 6 of 8 sectors affected, 1 range
    - Affected sectors 0 to 5 (0x8000000 - 0x803FFFF)
    - RAM tested O.K.
    - Erase operation completed successfully
    - Programming target (195504 bytes, 1 range) ...
    - Target programmed successfully
    - Verifying CRC of affected sectors ...
    - CRC of affected sectors verified successfully (CRC = 0x3706E77B)
    - Secure chip ...
    - Chip secured successfully
    - De-initializing CPU core (Exit sequence) ...
    - De-initialized successfully
    - Target erased, programmed and verified successfully - Completed after 19.634 sec
    - Starting application ...
    - Disconnecting ...
    - Disconnected
    - Target application started
    Many thanks for your help
    Patrick
    • project.jflash
      (1.89 kB, downloaded 731 times, last: )
    Be patient... we all have work to do...
    I have seen this behavior on the STM32 devices before.
    After securing the device, it seems they need a power on reset in order to boot correctly.
    It seems to have something to do with changing from unsecured state to secured state.
    So far, there is nothing J-Link can do to work-around this. A power-cycle is simply necessary to start the application, in case target state is changed from "unsecured" to "secured".
    - Alex
  • Hi Patrick,
    Sounds like a good plan to have this done at boot time.
    Anyhow, I do not think there is a real work-around for this
    but this problem is not a blocking problem, it is just a uncomfortable behavior.
    So right now, just something users of these devices have to live with...
