How do I setup LPCXpresso for use with my J-Link?
  • How do I setup LPCXpresso for use with my J-Link?
    How do I setup LPCXpresso for use with my J-Link? I thought LPCXpresso worked through GDB and I could simply use SEGGER's GDB server. When trying this I get
    No compatible emulator available
    Do I have to change the port within LPCXpresso somehow?
  • Hi Patrick,
    Unfortunately this is not the case. LPCXpresso currently uses a more or less proprietary interface which is based on GDB in general but does not allow generic/vanilla GDB connections to third party GDBServers.
    So currently, you cannot use J-Link with LPCXpresso due to lack of support from the IDE side.
    - Alex
  • Hi Partick,
    LPCXpresso IDE V7.1 and later now comes with J-Link support.
    How to get up and running with LPCXpresso IDE + J-Link can be seen here:
    segger.com/nxp-lpcxpresso.html
    Unlimited flash breakpoints are also supported.
