Problem with jLink and SAM-BA
  • Problem with jLink and SAM-BA
    I have an AT91SAM9261-EK, along with a jLink device, and I am trying to use SAM-BA, and/or gdbserver + Eclipse. I am having limited success with all three scenarios. My SAM-BA problem first:
    -When I start SAM-BA, I get the dialog asking to select the connection, and \jlink\ARM0 does show up, so I click connect. Once I do that, after about 5 seconds another dialog pops up saying "DCC communication timeout during write" If I click 'ok', SAM-BA starts up just fine. When I load code into SDRAM, it gives me the same "DCC..." error message, but the code does get transferred, and it runs. If I try to load code into SRAM however, it does not run properly (no LEDs blinking on the board).
    If I use a USB connection directly to the board, instead of JTAG (jLink), everything works fine. No "DCC..." messages, the code runs fine out of both SDRAM and SRAM. Is there a clock setting or something for jLink that I am missing?
    I am having a whole other set of issues with using yagarto/eclipse/gdbserver, but I will save that for another post. :)
    Thanks for the help.
    The post was edited 1 time, last by budhe888 ().
  • Hello budhe888,
    we have fixed this issue in the J-Link software version 3.89c, so using the latest beta version (3.89j) should solve this problem.
    Simply install the latest beta version and replace the old JLinkARM.dll in your SAM-BA directory by the new one.
    The latest J-Link software version can be downloaded from our website: segger.com/download_jlink_beta.html
    It has been tested with J-Link Rev. 5 and J-Link Rev. 6
    Can you please download the latest beta version and confirm that it solves the problem?
  • Thanks Alex, that did fix the error message I was getting about DCC; I do not get that message anymore. However, functionally I am still unable to get a program to work in SRAM, loading it through SAM-BA and j-link. If I do it through j-link commander, it works just fine. The problem could be with SAM-BA, except that it works normally if I connect to the board through USB instead of JTAG.
    Adit
