problem connectin JLINK.exe to SAM-ICE
  • problem connectin JLINK.exe to SAM-ICE
    I have a sam-ice and am using J-link to connect to the SAM-ICE.
    I have an AT91SAM9260-EK
    I don't have the SAM-ICE connected to it -- I'm just trying to make sure I can connect the PC to the SAM ICE
    When I start JLink.exe,
    The SAM-ICE LED blinks like it is communicating with the PC and it says:
    SEGGER J-Link Commander V3.86g ('?' for help)
    Compiled Jul 11 2008 10:48:44
    Can not connect to J-Link via USB.
    J-Link>?
    Here are the results of some other commands:
    J-Link>f
    Unable to retrieve firmware info !
    J-LINK>st
    VTarget=0.000V
    ITarget=4213861mA
    TCK=0 TDI=0 TDO=0 TMS=0 TRES=0 TRST=0
    SupportedJ TAG Speeds:
    <then jlink.exe stops working and crashes>
    J-Link>hwinfo
    HWInfo[00] = Target power is enabled
    HWInfo[01] = OverCurrent (Unknown reason: 1244678)
    HWInfo[02] = 1244676mA (ITarget)
    HWInfo[03] = 2000963201mA (ITargetPeak)
    HWInfo[04] = 4980810mA (ITargetPeakOperation)
    HWInfo[05] = 0x006E0069
    HWInfo[06] = 0x002E006B
    HWInfo[07] = 0x00780065
    HWInfo[08] = 0x00000065
    HWInfo[09] = 0x01551CDD
    HWInfo[10] = 22350848ms (ITargetMaxTime0)
    HWInfo[11] = 4244150ms (ITargetMaxTime1)
    HWInfo[12] = 0ms (ITargetMaxTime2)
    HWInfo[13] = 0x01551CB0
    HWInfo[14] = 0x00000000
    HWInfo[15] = 0x00000007
    HWInfo[16] = 0x00000007
    HWInfo[17] = 0x01551CB7
    HWInfo[18] = 0x01550C00
    HWInfo[19] = 0x0040C2B6
    HWInfo[20] = 0x00000000
    HWInfo[21] = 0x00129264
    HWInfo[22] = 0x00000000
    HWInfo[23] = 0x00000000
    HWInfo[24] = 0x0012FDF8
    HWInfo[25] = 0x00404C65
    HWInfo[26] = 0x00000000
    HWInfo[27] = 0x00000000
    HWInfo[28] = 0x00000002
    HWInfo[29] = 0x0040F2E0
    HWInfo[30] = 0x01550C00
    HWInfo[31] = 0x00000000
    Any hints on what to try next? Do I have a SAM-ICE hardware problem? A jlink or driver problem or a just a user problem??
  • Hello cherice,
    Is the SAM-ICE LED continously flashing at a high frequency when you connect the SAM-ICE to the PC?
    If yes, it seems that the SAM-ICE can not be enumerated by the USB-controller.
    Could you please perform the steps described in the J-Link / J-Trace User Guide, chapter "Troubleshooting", section "Typical problem scenarios"?
    the crash-problem regarding the "st" command is fixed in the current J-Link software version (3.90).
    The latest software version can be downloaded from our website: segger.com/download_jlink.html
  • Jlink.exe to Sam-Ice for at91SSM9260-EK
    It turned out to be some sort of USB problem.
    I had installed the driver with ithe cable plugged into USB1, and it was expecting USB0, even after I moved the cable to the usb0 port it had trouble.
    So at the prompt, I typed usbaddr 0 and jlink prompted me to disconnect and reconnect the cable and re-installed the driver properly.
