SAM-ICE problem
  • SAM-ICE problem
    I have following problem with SAM-ICE. ARM processor no my board is not detected.
    When I connect USB-blaster (just for checking the JTAG) the processor is recognized,
    so Jtag connection is correct.
    Here is log from J-Link driver:
    SEGGER J-Link V4.72 Log File
    DLL Compiled: Jun 12 2013 15:47:08
    Logging started @ 2013-12-05 13:29
    T193C 2063:858 JLINK_ExecCommand("ProjectFile = ", ...) returns 0x00 (0000ms, 5278ms total)
    T193C 2063:858 JLINK_ExecCommand("device = AT91SAM3X8C", ...)
    JLINK_AddMirrorAreaEx(Addr = 0x00000000, Size = 0x00000000) (0000ms, 0000ms total)
    Device "AT91SAM3X8C" selected (512 KB flash, 64 KB RAM). returns 0x00 (0001ms, 5279ms total)
    T193C 2063:859 JLINK_TIF_Select(JLINKARM_TIF_JTAG) returns 0x00 (0000ms, 5279ms total)
    T193C 2063:859 JLINK_ConfigJTAG(IRPre = 0, DRPre = 0) (0000ms, 5279ms total)
    T193C 2063:859 JLINK_SelDevice(0) (0000ms, 5279ms total)
    T193C 2063:859 JLINK_SetSpeed(0) >0x2F8 JTAG>TotalIRLen = 5, IRPrint = 0x01 >0x30 JTAG> >0x210 JTAG> (0007ms, 5286ms total)
    T193C 2063:866 JLINK_Connect() >0x2F8 JTAG>TotalIRLen = 5, IRPrint = 0x01 >0x30 JTAG> >0x210 JTAG> returns 0xFFFFFFFF (0007ms, 5293ms total)
    Can you help me with this?
    A
    The response from the SAM3X does not really look okay...
    SAM-ICE detects a TotalIRLen of 5 bits, while it should be 4 bits if there is only the SAM3X in the JTAG chain.
    It seems that for some reason, an incorrect pattern detected on the TDO line.
    So far, I see two possible reasons for this:
    1) There is a faulty connection
    2) The SAM-ICE is damaged and therefore detects an incorrect pattern
    Are you working with an eval board or with custom hardware?
  • Hi Alex!
    Thanks for quick reply.
    I'm working with custom hardware and it seems that makes problems
    I've just connected SAM-ICE to Arduino Duo board and can read device ID,
    so the programmer is not damaged. I've tested with second one with the same result.
    I will continue to investigate the problem.
    The post was edited 1 time, last by andre858 ().
    Alright. Good to hear that everything is working now.
    Wow, amazing how many people are still using JTAG for Cortex-M based devices instead of SWD which requires less lines... :)
