I'm using the JLink to flash very small and low power devices, and then often measuring the power consumption of them as they run the new code. The SWD pins are typically for convenience still connected to my target system, but I don't know if their electrical state (hi, low, Z) is assured. What is the expected state ? If "Z", what's the expected leakage current if the SWDCLK pin is pulled low and the SWDIO pin is pulled high (both with 100K resistors) ?
Also, is my understanding that the I/O drive levels are set by the voltage sensed on pin 1 of the 20 pin connector ? How low can this operate ?
Thanks, -Russ
Thanks, -Russ
