Accessing Embedded Internal Flash (2MB) on STM32F429I-EVAL board
  • Accessing Embedded Internal Flash (2MB) on STM32F429I-EVAL board
    I am working on STM32F429I-EVAL board with JLINK (Ver 4.76e) as Probe. I have successfully loaded and executed the hello world program on Internal Embedded SRAM (0x20000000; Size = 192K).
    But I am unable to access Embedded Internal Flash (0x08000000; Size = 2MB).
    Moreover, Internal Flash is working fine with STM32 ST-LINK Utility (Version 3.1.0)
    Is there any programming sequence to enable this Flash?
    Is there any multiplexing by default?
    The post was edited 2 times, last by hafizqasim ().
    What do you mean with "But I am unable to access Embedded Internal Flash"?
    Do you mean reading the flash does not work?
    Programming it does not work?
    What IDE / environment / utility are you using in order to "access" the flash?
    I am trying to load/Flash my binary on Internal Flash (Address: 0x08000000; Size 2MB) using JLINK (V4.76e) but it is not loading; see attached image for error message
    However, If I try to load and then execute program on Internal Ram only (SRAM; Address: 0x20000000; Size=192K) using JLINK, it is loading and executing fine.
    Moreover, If I try to load and then execute program in Internal Flash and Internal RAM using STM32 ST-LINK Utility, It is loading and executing fine.
    Also, If I try to load and then execute program in PSRAM (Address: 0x68000000; Size = 64MB), it is not loaded
    Tools and Tech Used: Sourcery Code Bench and JLINK
    So you are using J-Link + GDBServer for downloading into flash.
    Did you follow the instructions in UM08005 (GDBServer User Guide) for enabling flash download via GDBServer?
    segger.com/jlink-software.html
    Basically it is:
    Select the correct device in the GDBServer configuration dialog shown at startup and then just perform a regular download into flash as you would do into RAM.
    That's it.
