[SOLVED] Semihosting on STM32 with GNU ARM Embedded, Eclipse and JLink GDB Server
  • [SOLVED] Semihosting on STM32 with GNU ARM Embedded, Eclipse and JLink GDB Server
    Hi
    I'm facing an issue regarding the semihosting mode with a STM32F207ZG (Cortex M3) and a J-Link (Lite).
    I use the latest GNU ARM embedded 4.7 2013q2 and Eclipse.
    Code :
    1. #include <stdio.h>
    2. int main(void)
    3. {
    4. RCC_ClocksTypeDef RCC_Clocks;
    5. STM_EVAL_LEDInit(LED4);
    6. /* Initialize User_Button */
    7. STM_EVAL_PBInit(BUTTON_USER, BUTTON_MODE_GPIO);
    8. /* SysTick end of count event each 1ms */
    9. RCC_GetClocksFreq(&RCC_Clocks);
    10. SysTick_Config(RCC_Clocks.HCLK_Frequency / 1000);
    11. while(1)
    12. {
    13. /* Check if the user button is pressed */
    14. if(STM_EVAL_PBGetState(BUTTON_USER) == 0) {
    15. printf("Hello World !\n");
    16. STM_EVAL_LEDOn(LED4);
    17. /* wait for 1s */
    18. Delay(1000);
    19. /* Turn off LED after 1s each time User button is pressed */
    20. STM_EVAL_LEDOff(LED4);
    21. }
    22. }
    23. }
    Linker options :
    1. "-Wl,-Map=${BuildArtifactFileBaseName}.map" -T"..\stm32_flash.ld" -Wl,--gc-sections -mthumb -mcpu=cortex-m3 --specs=rdimon.specs -Wl,--start-group -lgcc -lc -lm -lrdimon -Wl,--end-group
    as indicated in the GNU ARM Embedded readme.txt (launchpadlibrarian.net/143625601/readme.txt)
    GDB command :
    1. arm-none-eabi-gdb
    Initialization commands :
    1. target remote localhost:2331
    2. monitor interface SWD
    3. monitor endian little
    4. monitor speed auto
    5. monitor semihosting enable
    6. monitor flash device = STM32F207ZG
    7. monitor flash download = 1
    8. monitor reset
    I get these errors in the J-Link GDB Server log (v4.76a)
    1. WARNING: Semihosting command SYS_FLEN failed. Handle is 0.
    2. WARNING: Semihosting command SYS_WRITE failed. Handle is 0.
    3. WARNING: Semihosting command SYS_WRITE failed. Handle is 0.
    4. WARNING: Semihosting command SYS_WRITE failed. Handle is 0.
    I'm almost sure I missed something very basic...
    Can you help ?
    Thanks !
    The post was edited 3 times, last by Efcis ().
  • Hi memphiscz
    Actually, the error disappeared after specifying
    1. extern void initialise_monitor_handles(void);
    and calling
    1. initialise_monitor_handles();
    at start of the main function.
    But I still can't see my "Hello World !" anywhere ?! The application console in Eclipse is empty.
    Did I miss something obvious ?
    And just for info, i think that Segger`s semihosting dont support write, only read.
    The current version (V4.76d) should also support writing for semihosting.
    Moreover, it also supports the GDB File I/O extensions for users who prefer getting/sending semihosting data directly from/via the GDB window.
