J-Link GDB Server - Problems setting HW breakpoints using JTAG interface
  • J-Link GDB Server - Problems setting HW breakpoints using JTAG interface
    I've recently started using J-LINK to try debug my application running on an STM32F1XX.
    When using the J-Link GDB server in JTAG mode, I am having issues setting HW breakpoints.
    When setting a breakpoint in GDB (for examble 'hbreak main'), I see the message in the server log "WARNING: No more breakpoint resources left". The breakpoint at main is never hit.
    However, when I configure the GDB server interface to use SWD, the above breakpoint works fine and the program will stop at main().
    As far as I can tell, the JTAG connection is wired properly. Also, the initial download and verification of application works fine over the JTAG interface. So far I am just running into problems with the debugging.
    Could someone please explain what I am seeing here?
    Thanks in advance,
    -Steven
  • Hi Steven,
    It should not be necessary to explicitly specify to set hardware breakpoints, since J-Link does this automatically as long as they are available.
    So far, I have no idea why it should work with SWD but not with JTAG, since this is absolutely target interface independent.
    Can you provide a project that allows reproduction of this?
  • Hi, I am not sure what you are asking me to provide...
    Anyway, installed SW version 4.42c (because this was the version that a college was using).
    I launched, the the GDB server (via JTAG), and then ran the same GDB session. I was then able to successfully break on main (unlike before using 4.76b)
    -Steven
  • Hi Steven,
    No problem, what I am asking for is the project you are using for debugging.
    What IDE / toolchain /environment do you use?
    Eclipse + GDB + GDBServer?
    emIDE + GDBServer?
    We would like to check what is going wrong there since according to your explanation, it works in a previous version, so it sounds like a problem in the current one.
    Could you please check V4.76e?
    We fixed a problem regarding hardware breakpoints on Cortex-M when using the JTAG interface.
    This problem did not occur when using SWD.
    Download-Link: segger.com/jlink-software.html
  • Hi Steven,
    Thanks for the confirmation. Good to hear that everything is working.
    - Alex
