Version 4.60: CONTROL is ok - BASEPRI still wrong endianness (Cortex-M3)
  • Version 4.60: CONTROL is ok - BASEPRI still wrong endianness (Cortex-M3)
    The CONTROL register is in version 4.60 correct, but the BASEPRI is still wrong.
    A priority of 0x28 (e.g. FreeRTOS) is still displayed at 0x2800.
    EmBlocks users:
    Keep the shifting in the squirrel scripting arm-gdb-reg.script for the basepri
    1. ////////////////////////////////////////////////////////////////////////////////
    2. // The ARM BASEPRI register
    3. ////////////////////////////////////////////////////////////////////////////////
    4. /////////////////////////////////////////////////////////
    5. // Function returns: comma seperated list
    6. //
    7. function parse_bpri(value)
    8. {
    9. local result = ::wxString();
    10. // Correct the endiannesses of Segger J-link
    11. value = (value >>8)&0xFF;
    12. result = _T("");
    13. result += _T("BASEPRI=");
    14. result += ::wxString.Format(_T("0x%02X;"), value );
    15. result += ::wxString.Format(_T("%u,"), value );
    16. return result;
    17. }
    18. /////////////////////////////////////////////////////////
    19. // Function
    20. //
    21. // member : wxString -> register member
    22. // regval : unsigned long -> the value of the parent register
    23. // memval : unsigned long -> the new value for the register member
    24. //
    25. // returns: wxString which is directly used for the GDB command driver
    26. //
    27. function set_bpri(member, regval, memval)
    28. {
    29. local result = ::wxString();
    30. if( member.Matches(_T("BASEPRI") ) )
    31. {
    32. regval = memval & 0xFF;
    33. }
    34. // Correct the endiannesses of Segger J-link
    35. regval = regval << 8;
    36. result = result.Format(_T("0x%X"),regval );
    37. return result;
    38. }
  • This will be fixed in the next patched version (V4.60b)
    Johannes
