Serial Wire Multi Drop
  • Serial Wire Multi Drop
    My plan is to validate that I can address both a Freescale Kinetis KXX (Cortex-M4) and a Kinetis KLXX (Cortex-M0+) on a same board using a single debug connector.
    As Kinetis L serie has only Serial Wire interface (so JTAG chaining seems not to be an option), I imagine connecting both MCUs in parallel on SWDIO and SWDCLK and use the multi-drop extensions defined as part of Serial Wire protocol version 2 in ADI (ARM Debug Interface) v5.1.
    I briefly tried to connect two TWRK40 boards in such parallel configuration but I manage to connect to only one of the two targets.
    My questions are the following :
    - Does J-Link already allow to address multiple targets through a single Serial Wire connection ?
    - If not, is there a plan to do so ?
    - What is your feeling about such plan ?
    Kind regards,
    SWD Multi-drop is not supported yet.
    There are definitely plans to support this but I can not give you a schedule yet.
    I will check internally.
    I checked this and we plan to add support for SWD multi-drop sometime this year.
