[SOLVED]JLink connection with Freescale Kinetis K70
  • [SOLVED]JLink connection with Freescale Kinetis K70
    Hi
    I am trying to load bare metal C Program [calculating factorial of a number] on K70F120M using JLINK [JLinkARM V442b] and CodeBench. When I try to load in RAM [internal], it is loaded and executed successfully.
    But when I try to load on ROM [program flash], it is not connected. Following error message is displayed.
    Failed to execute MI Command.
    -target -download
    Error Message from debugger back end
    Error finishing flash operation
    Is JLink Support Programming Flash on K70F120M board? If yes, Am I missing some configurations?
    In general, your device is supported by the JLink.
    We need some information to help you:
    - Which version of CodeBench are you using?
    - Could you provide your (or a sample) project for the K70?
    So we can find out why programming flash does not work.
    Johannes
  • Hi
    Sorry for late reply.
    CodeBench Version: Sourcery CodeBench Version: 2012.03-69
    JLINK Version: JLinkARM_V442b
    Sample Project:
    #include <stdio.h>
    int factorial(int n) {
    if (n == 0)
    return 1;
    return n * factorial (n - 1);
    int main () {
    int i;
    int n;
    for (i = 0; i < 10; ++i) {
    n = factorial (i);
    return 0;
    Thanks for the information.
    I'm sorry but I cannot find your CodeBench Version. All I know, CodeBench for Kinetis EABI is version 2012.03-36 and for ARM EABI it is version 2012.03.28.
    But which one are you using?
    Is it possible to send me a complete project for CodeBench with your configurations, so I can reproduce your error.
    Johannes
  • You may use version 2012.03.28.
    Currently, I am trying a simple bare metal project having only one file say first.c with code
    #include <stdio.h>
    if (n == 0)
    return 1;
    int main () {
    int i;
    int n;
    n = factorial (i);
    return 0;
    There is no special project setting/configurations
    Thanks for the info.
    We will try to reproduce with 2012.03.28
    We also created a small sample project for the K70 series and so far it works fine.
    Testing Environment:
    - J-Link DLL V4.54a
    - CodeBench 2012.03.28
    - K70FN1M0xxx12
    What needs to be done to test the project on your side:
    - Download the attachment
    - Extract it and import the project into your environment
    - Select the J-Link settings file (see screenshot below)
    - Build project and start debug session
    Short feedback would be appreciated.
    Johannes
    • TWR-K70.zip
      (25.85 kB, downloaded 680 times, last: )
    I'm sorry. I thought it was in the zip.
    Now find it attached to this post.
    Johannes
    Good to hear that everything is working also on your side.
