Rotating SLIDER or SCROLLBAR widget
  • Rotating SLIDER or SCROLLBAR widget
    1. If the SLIDER is vertical, the min value is on the top, the max on the bottom. Is there a way to swap the two so the position increases as the SLIDER moves up?
    2. Is there a way to set a range for a SCROLLBAR like there is for a SLIDER so that the min value can be something other than 0?
