Flash a STM32F407VG with JLink EDU produces Errors
  • Flash a STM32F407VG with JLink EDU produces Errors
    Hi
    I would like flash my STM32F407VGT Board, but get Error-messages while flashing.
    My Script (i work under Linux):
    1. /usr/local/bin/JLinkExe << EOF
    2. exec EnableFlashDL
    3. exec Device=STM32F407VG
    4. speed 100
    5. h
    6. loadbin ./project.bin, 0x0000
    7. r
    8. g
    9. exit
    10. EOF
    Error-Messages:
    Brainfuck Source Code
    1. SEGGER J-Link Commander V4.50i ('?' for help)
    2. Compiled Jun 22 2012 19:00:38
    3. DLL version V4.50i, compiled Jun 22 2012 19:00:36
    4. Firmware: J-Link ARM V8 compiled Jul 20 2012 16:33:52
    5. Hardware: V8.00
    6. S/N: 268000082
    7. OEM: SEGGER-EDU
    8. Feature(s): FlashBP
    9. VTarget = 3.254V
    10. Info: TotalIRLen = 9, IRPrint = 0x0011
    11. Info: Found Cortex-M4 r0p1, Little endian.
    12. Info: TPIU fitted.
    13. Info: ETM fitted.
    14. Info: FPUnit: 6 code (BP) slots and 2 literal slots
    15. Found 2 JTAG devices, Total IRLen = 9:
    16. #0 Id: 0x4BA00477, IRLen: 04, IRPrint: 0x1, CoreSight JTAG-DP (ARM)
    17. #1 Id: 0x06413041, IRLen: 05, IRPrint: 0x1, STM32 Boundary Scan
    18. Cortex-M4 identified.
    19. JTAG speed: 100 kHz
    20. J-Link>exec EnableFlashDL
    21. J-Link>exec Device=STM32F407VG
    22. Info: Device "STM32F407VG" selected (1024 KB flash, 128 KB RAM).
    23. J-Link>speed 100
    24. JTAG speed: 100 kHz
    25. J-Link>h
    26. R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000
    27. R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000
    28. R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000
    29. R12= 00000000, R13= FFFFFFFC, MSP= FFFFFFFC, PSP= 00000000
    30. R14(LR) = FFFFFFFF, R15(PC) = FFFFFFFE
    31. XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000
    32. CFBP 00010000, CONTROL 00, FAULTMASK 01, BASEPRI 00, PRIMASK 00
    33. FPS0 = 00000000, FPS1 = 00000000, FPS2 = 00000000, FPS3 = 00000000
    34. FPS4 = 00000000, FPS5 = 00000000, FPS6 = 00000000, FPS7 = 00000000
    35. FPS8 = 00000000, FPS9 = 00000000, FPS10= 00000000, FPS11= 00000000
    36. FPS12= 00000000, FPS13= 00000000, FPS14= 00000000, FPS15= 00000000
    37. FPS16= 00000000, FPS17= 00000000, FPS18= 00000000, FPS19= 00000000
    38. FPS20= 00000000, FPS21= 00000000, FPS22= 00000000, FPS23= 00000000
    39. FPS24= 00000000, FPS25= 00000000, FPS26= 00000000, FPS27= 00000000
    40. FPS28= 00000000, FPS29= 00000000, FPS30= 00000000, FPS31= 00000000
    41. FPSCR= 00000000
    42. J-Link>loadbin /home/a239368/personal/Mikrocontroller/Cortex/stm32f4/mikromedia/project.bin, 0x0000
    43. Loading binary file... [/home/a239368/personal/Mikrocontroller/Cortex/stm32f4/mikromedia/project.bin]
    44. Writing bin data into target memory @ 0x00000000.
    45. ****** Error: PC of target system has unexpected value after calculating CRC. (PC = 0x20000054)!
    46. ---------------------------------------------------------------------- Registers -------------------------------------------------------------------------------------
    47. PC = 20000054
    48. Current: R0 = 00000000, R1 = 08000000, R2 = 00004000, R3 = 00000003
    49. R4 = 20000358, R5 = 200003B8, R6 = 000000FF, R7 = 20000147
    50. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------
    51. Info: J-Link: Flash download: Flash programming performed for 1 range (0 bytes)
    52. ****** Error: Failed to erase sectors 0 @ address 0x08000000 (erase error)
    53. Info: J-Link: Flash download: Total time needed: 7370.504s (Prepare: 1.692s, Compare: 0.078s, Program: 0.000s, Verify: 7367.605s, Restore: 1.126s)
    54. J-Link>r
    55. Reset delay: 0 ms
    56. Reset type NORMAL: Resets core & peripherals via SYSRESETREQ & VECTRESET bit.
    57. Info: Found Cortex-M4 r0p1, Little endian.
    58. Info: TPIU fitted.
    59. Info: ETM fitted.
    60. Info: FPUnit: 6 code (BP) slots and 2 literal slots
    61. J-Link>g
    62. J-Link>exit
    What am i doing wrong ? On other boards with STM32F107, it works well.
    Thanks for any help
    Daniel
  • Hi Daniel,
    We are not aware of any flashing problems with STM32F4 devices in the current version.
    Is the bin file you are downloading a generic application which also runs on an eval board?
    If yes, would it be possible to attach the bin file to your answer?
    Moreover: Have any option bytes of the device been programmed previously?
  • Hi Alex
    Thanks for the answer
    The target board is a mikroe.com/eng/products/view/869/mikromedia-for-stm32-m4/
    Connection is from the JLink-EDU over the ST-Link V2 Adapter (on the mikroe webpage below) to the JTAG-Header (solderd in by me) of the board.
    The binary is the working "Blinky" example from the st.com/internet/evalboard/product/252419.jsp STM32F4Discovery board.
    It's compiled by me, is flashable over the USB-port with the "stlink" utility on Linux, and it runs.
    I can attach the binary this afternoon, when i'am at home.
    But the longer i think the more i'am afraid that i killed my board. The first time when i tried my setup, i connected the board to the JLink-EDU in a wrong way.
    The power regulator went very hot, and i unpluged the hole thing. After changing the setup, the connection seems to be ok. A Cortex-M4 CPU is found by the
    JLink-EDU and i tried a couple of things to flash. After that, i recognised, that the bootloader on the board did not work anymore. I thought its because of my flash-tests, but it's also possible, that i destroyed something with my wrong setup.
    Do i have a change to check the CPU over the JLink-EDU with some commands, to see if its broken or not ?
    Daniel
  • Hi Daniel,
    You can perform several checks via J-Link Commander like Go ("g"), Halt ("h"), Step ("s"), ReadMem() WriteMem(), ...
    Just type "?" to get a list of all supported commands.
  • [Solved]Flash a STM32F407VG with JLink EDU produces Errors
    Hi
    I solved the problem for me.
    Solution: I changed to the original ST-LINK/V2 adapter, and this adapter (or better the ST-Link Utility Software) told me
    after the first connect, that the "ReatOut Protection" was set to "Level 1: memory read protection enabled" in the so called "Option Bytes".
    Reset that to "Level 0: no protection", and everything works fine.
    Information: microcodes.info/stm32f4-how-to…-option-bytes-135151.html
    Maybe your software does not cover that, or i didn't find the hint in the error messages or in your documents ?
    Daniel
  • Hi Daniel,
    Currently, J-Link indeed does not check for the device security being active since it makes no sense to activate it while still debugging the device...
    Nevertheless, we will add a mechanism for the STM32 devices which also checks the device security at connect and allows a unsecure (if possible depends on the security level).
    This mechanism will be available if the correct device is selected in the debugger / J-Link Commander.
