"Error: Supply voltage too low" with J-Link and BeagleBoard
  • "Error: Supply voltage too low" with J-Link and BeagleBoard
    I've tried to use J-Link to flash BeagleBoard rev.B4 with cpu OMAP3530 (Cortex a8 core).
    On PC I have Ubuntu 11.10 so I installed drivers for jlink on linux (use V4.41g).
    But after installing, connecting to board and runnig JLinkExe i take this:
    SEGGER J-Link Commander V4.41g ('?' for help)
    Compiled Jan 27 2012 19:11:22
    ****** Error: Could not save file [Default.ini]
    Invalid file handle!
    DLL version V4.41g, compiled Jan 27 2012 19:11:21
    Firmware: J-Link ARM V8 compiled Jan 12 2012 20:43:19
    Hardware: V8.00
    S/N: 58001333
    Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    VTarget = 0.957V
    ****** Error: Supply voltage too low (1 Volt is required, Measured: 0.9 Volt).
    Please check target power.
    No devices found on JTAG chain. Trying to find device on SWD.
    WARNING: RESET (pin 15) high, but should be low. Please check target hardware.
    No device found on SWD.
    Did not find any core.
    So as I see there problem with with supply voltage on pin 1.
    But I used this Jlink with board LPC2138 while working on PC with Windows and it works great. So I think its not a problem with JLink.
    I havent opportunity to try use beagleboard on windows, so I need solve this problem on ubuntu.
    Can it be related with drivers for jlink? Or its problem in target board?
    The post was edited 1 time, last by MrTea ().
    0.957V is definitely to low as target reference voltage.
    Sounds like a target hardware problem to me.
    Not exactly sure on what voltage the JTAG interface of the OMAP3530 is running,
    but it is definitely higher than 0.957V...
  • Finally I think I found out what problem occured.
    Jlink uses standard ARM 20-pin JTAG interface, Beagleboard 14-pin JTAG, so I use 14/20 pin JTAG converter to connect it.
    But beagleboard uses not classic ARM jtag. Board comes with a 14 pin TI JTAG connector, so they have different pinout.
    Fortunately, it isn't fried my board and it's still working.
    Yes, most TI Cortex-A based boards come with a 14-pin TI JTAG connector.
    We also offer adapters for such boards: segger.com/jlink-adapters.html#TI
    So, it seems you simply connected the J-Link via the ARM 14-pin Adapter (or some self-made adapter), which has a different pinout, to the board
    which made things to NOT work correctly. So I think we can close this thread for now.
