[SOLVED]JLink Failed to erase sectors 0 @ address 0x00000000
  • [SOLVED]JLink Failed to erase sectors 0 @ address 0x00000000
    When I connect mk60n512 target board via JLinkGDBServer, the log says:
    02-00-00015893-0037: JLINK_GoIntDis() (0002ms, 0192ms total)
    02-00-00015897-0045: JLINK_IsHalted() returns TRUE (0004ms, 0194ms total)
    02-00-00015897-004D: JLINK_ReadReg(R15) returns 0x1FFFC000 (0000ms, 0198ms total)
    02-00-00015897-004C: JLINK_ReadReg(R0) returns 0xFFFFFFFE (0000ms, 0198ms total)
    02-00-00015897-000E:
    02-00-00015904-009B: ***** Error: Failed to erase sectors 0 @ address 0x00000000 (Algo135: Flash protection violation. Flash is write-protected.) -- End of flash programming
    02-00-00015904-004A: JLINK_GetDeviceFamily() returns 14 (0000ms, 0198ms total)
    03-00-00015904-0076: ERROR: Failed to erase sectors 0 @ address 0x00000000 (Algo135: Flash protection violation. Flash is write-protected.)
    03-00-00015999-001F: Connection to debugger closed !
    I am not sure how to fix this issue, so could anybody help me?
    Thanks very much.
    is it possible that the flash got write-protected by accident?
    If yes, please open the J-Link Commander and type
    unlock Kinetis
    in order to trigger a mass erase of the flash memory via the MDM-AP of the Kinetis device.
    Is the GDBServer then able to program the MK60N512?
    Which version of the GDBServer do you use (current one is V4.36k (release) / V4.39a (beta))?
  • I was using JLink 4.28c and J-Link seems not working right, it did not prompt me a command line and just hanged.
    Don't know whether related to my cygwin or system environment.
    Anyway I switched Jlink 4.36i on another pc and unlock command ran successfully.
    Thank you for your quick support.
    The post was edited 1 time, last by can.finner ().
