[SOLVED][J-Link + J-Flash] Programming external flash memory in a custom AT91RM9200 based board.
  • [SOLVED][J-Link + J-Flash] Programming external flash memory in a custom AT91RM9200 based board.
    I'm interested in using J-Link/J-FlashBundle (8.08.11) for external flash programming of a custom ARM based board.
    The custom board has:
    • AT91RM9200 uController
    • External Flash memory: Sharp LH28F128BFHT-PTTL75A (8Mb x 16)
    • External SDRAM: Micron MT48LC8M16A2
    • 20 pin JTAG ICE connector
    I need to take the .MEM file obtained from a Green Hills Multi compiler and program it using J-Link/J-Flash into the external Sharp Flash memory.
    Regarding the combination of AT91RM9200 and Sharp’s LH28F128BFHT-PTTL75A, I have the following questions:
    1. Do I have to set-up or configure the J-Link device?
    2. Do I have to set-up or configure a new project for the J-Flash application (including init sequence)?
    3. Could I use a sample project (i.e.:AT91RM9200_EK.jflash) and adapt it easily to our board hardware? And after that, save it and use it for next time?
    Thanks in advance!
    Diego.
  • Hi Diego,
    Yes, you will need a J-Flash project to use J-Flash in order to program your device.
    The AT91RM9200_EK.flash project may be used with small modifications if your hardware is almost compatible to the eval board
    but even if it is not, it should be max. 1 day of work to get you up and running.
  • Hi Diego,
    Thanks for the feedback.
    Good to hear that it worked for you without any additional modification.
