SR6Px JFlash setup
  • Dear Segger Community,
    I'm trying to set up the ST Eval board ST_SR6PX-EVBC4000P. Tied to connect as described in the wiki - https://kb.segger.com/ST_SR6PX-EVBC4000P. I have target interface as SWD with 6000 kHz and do not have any special Init steps defined and also no JLink script is used.
    I tried with some init steps like Global freeze debug register configuration and Wdg deactivation. However, did not make any difference.
    I suppose there shall be some Init steps that shall be followed, like ECC RAM Initialization, and the mentioned ones in the line above.
    This is the JFlash log.
    Connecting ...
    - Connecting via USB to probe/ programmer device 0
    - Device "SR6P7G7X_CLUSTER_0_R52_0" selected.
    - Target interface speed: 6000 kHz (Fixed)
    - VTarget = 2.857V
    - ConfigTargetSettings() start
    - ConfigTargetSettings() end - Took 31us
    - InitTarget() start
    - DAP: Could not power-up system power domain.
    - Powering the core power domain failed.
    - Enabling debug mode failed.
    - No valid BCR header found.
    - Reset: Halt core immediately after reset using reset catch.
    - InitTarget() end - Took 367ms
    - Connect failed. Resetting via Reset pin and trying again.
    - ConfigTargetSettings() end - Took 30us
    - InitTarget() end - Took 266ms
    - ERROR: Failed to connect.
    Could not establish a connection to target.
    General troubleshooting guide: https://kb.segger.com/J-Link_Troubleshooting
    Device specific guide: https://kb.segger.com/ST_SR6P7G7x
    - ERROR: Connect failed
    Appreciate any support on this. Thanks!
    Aghil
