JLinkExe does not support file names with UTF-8 letters
  • Hello.
    Configuration:
    • operating system = Linux Ubuntu 20.04
    • JLink software Debian package v8.38 (64 bits)
    • JLinkExe = SEGGER J-Link Commander V8.38 (Compiled May 28 2025 12:46:55)
    • device = J-Link Base (running J-Link V11 compiled Apr 1 2025 10:02:30)
    It looks like the "JLinkExe" binary is not able to read command input encoded in UTF-8.
    I need to load a .hex file named for example "file_with_utf8_é.hex".
    Note the "é" letter in the file name, which is very common in my language.
    Running JLinkExe, when I manually try to type on my keyboard the command "loadfile file_with_utf8_é.hex"
    I can not enter the "é" letter (my key stroke is just ignored by JLinkExe), and therefore I can not enter the correct file name.
    I have a dedicated "é" key on my keyboard, and pressing that key is ignored by JLinkExe.
    Actually this issue was discovered when using a bash shell script used by our factory to automatize loading first firmware to MCU embedded flash.
    The .hex file name is generated and may have UTF-8 letters in its name.
    So it's not possible for us to simply avoid such letters.
    For your information, here is this bash script :
    If I run this script with "./flash.sh file_with_utf8_é.hex", then JLinkExe shows "Downloading file [file_with_utf8_.hex]..." (note the missing "é" letter) and fails with error "Failed to open file".
    If I rename the file to "file_with_no_utf8.hex"' and run "./flash.sh file_with_no_utf8.hex", then no error occurs.
    The J-Link Commander currently supports only ANSI-encoded strings for file names.
    However, you can flash files with UTF-8 encoding using J-Flash:
    1. Create a J-Flash project for your target.
    2. Flash your data file using the J-Flash CLI options.
      Example:
      JFlash.exe -openprj "stm32f407ve.jflash" -open "HSS_Example_é.hex" -auto -exit
    For more details on J-Flash CLI options, please refer to:
    J-Flash Command Line Interface
    Let me know if this works for you or if you need assistance setting up the project.
    Simon
