Necessity of SEGGER_SYSVIEW_LOCK()/UNLOCK()
  • SystemView's manual page 68 currently states:
    This section is also linked to in the FreeRTOS with SystemView entry on the SEGGER Knowledge Base (https://kb.segger.com/FreeRTOS_with_…ding_Interrupts) where it says:
    Locking Interrupts
    Every interrupt which directly or indirectly generates SystemView events needs to be locked by SEGGER_SYSVIEW_Lock().Make sure the interrupt priority and the lock configuration matches.
    Note, the mention of "SEGGER_SYSVIEW_Lock()" in the KB hyperlinks directly to the above quoted part of the manual, I assume "LOCK" isn't used in all capitals as a stylistic choice or an accident, not because there are two different APIs with different capitalisation :D
    This raises some confusion, as it could be interpreted as suggesting that interrupts need to be wrapped in SEGGER_SYSVIEW_LOCK()/SEGGER_SYSVIEW_UNLOCK(). Although, I've been wrapping my (FreeRTOS based system) interrupts in traceISR_ENTER()/traceISR_EXIT(). If I follow the macro trail for a bit, these lead to SEGGER_SYSVIEW_RecordEnterISR()/SEGGER_SYSVIEW_RecordExitISR(), both of these call RECORD_START and RECORD_END. And it seems that these macros call SEGGER_SYSVIEW_LOCK()/SEGGER_SYSVIEW_UNLOCK() respectively (provided that SEGGER_SYSVIEW_USE_STATIC_BUFFER is enabled!).
    Does this mean that as long as SEGGER_SYSVIEW_USE_STATIC_BUFFER is on, the traceISR_ENTER() ,traceISR_EXIT() and traceISR_EXIT_TO_SCHEDULER() macros are sufficient and all I need to use when recording interrupts?
    (Using FreeRTOS 10.6 here, with SystemView instrumentation patches based on the provided SystemView FreeRTOS 10.4 sample code.)
