J-link debugger crashes with unaligned hard fault when stepping through switch/case C code.
  • Microchip ATSAMs70n20
    If I step in disassembly, it is fine. but when I step in the c source, it crashes at the switch/case statement.
    key = getkey();
    switch (key) // crash to hard fault if step this.
    case RS_TRIG_CMD_PARTIAL:
    Mon May 05, 2025 17:16:55: IAR Embedded Workbench 9.60.3 (C:\iar\ewarm-9.60.3\arm\bin\armPROC.dll)
    Mon May 05, 2025 17:16:55: Loaded macro file: C:\iar\ewarm-9.60.3\arm/config/debugger/Microchip/SAMx70.dmac
    Mon May 05, 2025 17:16:55: PC-locked license - IAR Embedded Workbench for ARM
    Mon May 05, 2025 17:16:55: J-Link library version: 81001
    Mon May 05, 2025 17:16:55: JLINK command: ProjectFile = D:\work\10420\firm_s10420_s70n20\settings\s10420_Debug.jlink, return = 0
    Mon May 05, 2025 17:16:55: Device "ATSAMS70N20A" selected.
    Mon May 05, 2025 17:16:55: DLL version: V8.10a, compiled Oct 2 2024 14:15:45
    Mon May 05, 2025 17:16:55: Firmware: J-Link Pro V4 compiled Sep 22 2022 15:00:37
    Mon May 05, 2025 17:16:55: Serial number: 174504252
    Mon May 05, 2025 17:16:55: Selecting SWD as current target interface.
    Mon May 05, 2025 17:16:55: JTAG speed is initially set to: 1000 kHz
    Mon May 05, 2025 17:16:55: Found SW-DP with ID 0x0BD11477
    Mon May 05, 2025 17:16:55: DPIDR: 0x0BD11477
    Mon May 05, 2025 17:16:55: CoreSight SoC-400 or earlier
    Mon May 05, 2025 17:16:55: Scanning AP map to find all available APs
    Mon May 05, 2025 17:16:55: AP[1]: Stopped AP scan as end of AP map has been reached
    Mon May 05, 2025 17:16:55: AP[0]: AHB-AP (IDR: 0x04770041, ADDR: 0x00000000)
    Mon May 05, 2025 17:16:55: Iterating through AP map to find AHB-AP to use
    Mon May 05, 2025 17:16:55: AP[0]: Core found
    Mon May 05, 2025 17:16:55: AP[0]: AHB-AP ROM base: 0xE00FD000
    Mon May 05, 2025 17:16:55: CPUID register: 0x410FC271. Implementer code: 0x41 (ARM)
    Mon May 05, 2025 17:16:55: Cache: L1 I/D-cache present
    Mon May 05, 2025 17:16:55: Found Cortex-M7 r0p1, Little endian.
    Mon May 05, 2025 17:16:55: FPUnit: 8 code (BP) slots and 0 literal slots
    Mon May 05, 2025 17:16:55: CoreSight components:
    Mon May 05, 2025 17:16:55: ROMTbl[0] @ E00FD000
    Mon May 05, 2025 17:16:55: [0][0]: E00FE000 CID B105100D PID 000BB4C8 ROM Table
    Mon May 05, 2025 17:16:55: ROMTbl[1] @ E00FE000
    Mon May 05, 2025 17:16:55: [1][0]: E00FF000 CID B105100D PID 000BB4C7 ROM Table
    Mon May 05, 2025 17:16:55: ROMTbl[2] @ E00FF000
    Mon May 05, 2025 17:16:55: [2][0]: E000E000 CID B105E00D PID 000BB00C SCS-M7
    Mon May 05, 2025 17:16:55: [2][1]: E0001000 CID B105E00D PID 000BB002 DWT
    Mon May 05, 2025 17:16:55: [2][2]: E0002000 CID B105E00D PID 000BB00E FPB-M7
    Mon May 05, 2025 17:16:55: [2][3]: E0000000 CID B105E00D PID 000BB001 ITM
    Mon May 05, 2025 17:16:55: [1][1]: E0041000 CID B105900D PID 000BB975 ETM-M7
    Mon May 05, 2025 17:16:55: [0][1]: E0040000 CID B105900D PID 000BB9A9 TPIU-M7
    Mon May 05, 2025 17:16:55: I-Cache L1: 16 KB, 256 Sets, 32 Bytes/Line, 2-Way
    Mon May 05, 2025 17:16:55: D-Cache L1: 16 KB, 128 Sets, 32 Bytes/Line, 4-Way
    Mon May 05, 2025 17:16:55: Reset type: NORMAL (https://wiki.segger.com/J-Link_Reset_Strategies)
    Mon May 05, 2025 17:16:55: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    Mon May 05, 2025 17:16:55: Reset: Reset device via AIRCR.SYSRESETREQ.
    Mon May 05, 2025 17:16:55: Hardware reset with strategy 0 was performed
    Mon May 05, 2025 17:16:55: Initial reset was performed
    Mon May 05, 2025 17:16:55: POWERTRACE: Emulator buffer size: 25768 bytes
    Mon May 05, 2025 17:16:56: Loaded debugee: D:\work\10420\firm_s10420_s70n20\Debug\Exe\s10420.out
    Mon May 05, 2025 17:16:59: Auto speed detection, JTAG speed is set to: 2000 kHz
    Mon May 05, 2025 17:16:59: J-Link: Flash download: Bank 0 @ 0x00400000: 2 ranges affected (122880 bytes)
    Mon May 05, 2025 17:16:59: J-Link: Flash download: Total: 2.841s (Prepare: 1.148s, Compare: 0.131s, Erase: 0.586s, Program & Verify: 0.931s, Restore: 0.043s)
    Mon May 05, 2025 17:16:59: J-Link: Flash download: Program & Verify speed: 128 KB/s
    Mon May 05, 2025 17:16:59: 175596 bytes downloaded and verified (59.56 Kbytes/sec)
    Mon May 05, 2025 17:16:59: Download completed and verification successful.
    Mon May 05, 2025 17:16:59: Reset type: NORMAL (https://wiki.segger.com/J-Link_Reset_Strategies)
    Mon May 05, 2025 17:16:59: Reset: Halt core after reset via DEMCR.VC_CORERESET.
    Mon May 05, 2025 17:16:59: Reset: Reset device via AIRCR.SYSRESETREQ.
    Mon May 05, 2025 17:16:59: Software reset was performed
    Mon May 05, 2025 17:16:59: Target reset
    Mon May 05, 2025 17:16:59: Memory map 'after startup completion point' is active
    Mon May 05, 2025 17:18:04: Breakpoint hit: Code @ main.c:1025.14, type: default (auto)
    Mon May 05, 2025 17:18:14: Breakpoint hit: Code @ main.c:1025.14, type: default (auto)
    Mon May 05, 2025 17:19:07: Warning: Timeout while preparing target, RAMCode did not respond in time (PC = 0x0040D830, XPSR = 0x01000003, SP = 0x204005B0)!
    Mon May 05, 2025 17:19:07: Failed to prepare RAMCode using RAM
    Mon May 05, 2025 17:19:37: Breakpoint hit: Code @ main.c:1025.14, type: default (auto)
    Mon May 05, 2025 17:21:07: Breakpoint hit: Code @ main.c:1025.14, type: default (auto)
    Mon May 05, 2025 17:21:15: Breakpoint hit: Code @ main.c:1025.14, type: default (auto)
    Mon May 05, 2025 17:21:25: Warning: Timeout while preparing target, RAMCode did not respond in time (PC = 0x0040D830, XPSR = 0x01000003, SP = 0x204005B0)!
    Mon May 05, 2025 17:21:25: Failed to prepare RAMCode using RAM
    Mon May 05, 2025 17:21:25: Breakpoint hit: Code @ main.c:582.2, type: default (auto)
    Mon May 05, 2025 17:21:25: HardFault exception.
    Mon May 05, 2025 17:21:25: The processor has escalated a configurable-priority exception to HardFault.
    Mon May 05, 2025 17:21:25: An unaligned access error has occurred (CFSR.UNALIGNED).
    Mon May 05, 2025 17:21:25: Exception occurred at PC = 0x0, LR = 0x0
    Mon May 05, 2025 17:21:25: See the call stack for more information.
    Mon May 05, 2025 17:21:25: The stack pointer for stack 'CSTACK' (currently 0x2040'05b0) is outside the stack range (0x2045'fc00 to 0x2045'ffff)
    The log file indicates that J-Link is attempting to perform a flash operation and is preparing the flashloader.
    Depending on the number of cases in your switch statement, the available hardware breakpoints may not be sufficient. In such cases, flash breakpoints are automatically used.
    This requires the flash memory to be modified.
    However, during flashloader preparation, a timeout occurs.
    This prevents the flash breakpoints from being set and leaves the target in an error state.
    To further investigate, could you please check the following:
    • Does the issue also occur when reducing the number of case statements to fit within the available hardware breakpoints?
    • Does the issue persist when flash breakpoints are disabled?
    • Does your application implement any protection mechanisms that might prevent modification of the PC or other CPU registers?
    Simon
