Use JLink Commander to debug Cortex-A35
    I'm evaluation the use of JLink for ARM Cortex-A35 4CPU using JLink Plus.
    Connection fails because it doesn't find CTI. I assume I need to manually set the addresses of the debug port, CTI, ETB, etc, but could not find any suitable command.
    I could not find a useful example in the sample directory as well.
    Is there a script file I can use as guidelines?
    The next step is to test SDK based automation, so if you have any sample project it will be useful as well.
    Thank you!
    Hila
    You can find an example here:
    Template Example_ConfigTargetSettings_NXP_S32V234.JLinkScript
    Simon
  • Thank you Simon, It seems like a very good starting point because "my" A35 is very much like this one, it's a Quad core but with only one cluster (this one has two).
    Still I get the following error:
    onnecting to target via JTAG
    ConfigTargetSettings() start
    ConfigTargetSettings() end - Took 26us
    TotalIRLen = ?, IRPrint = 0x..FFFFFFFFFFFFFFFFFFFFFFF1
    Failed to identify target. Resetting via Reset pin and trying again.
    ConfigTargetSettings() end - Took 10us
    Error occurred: Could not connect to the target device.
    For troubleshooting steps visit: https://wiki.segger.com/J-Link_Troubleshooting
    Is it possible that my JLink Plus doesn't support A35?
    Here is my script after modification:
    __constant U32 _INDEX_AHB_AP_SYSTEM = 0; // AHB-AP connected to system bus with access to all peripherals etc.
    __constant U32 _INDEX_APB_AP_CORTEX_A = 1; // Index of AP that identifies the APB-AP that is connected to the Cortex-A cores
    __constant U32 _APB_ADDR_DBGREGS_A35_0 = 0x80090000;
    __constant U32 _APB_ADDR_DBGREGS_A35_1 = 0x80092000;
    __constant U32 _APB_ADDR_DBGREGS_A35_2 = 0x80094000;
    __constant U32 _APB_ADDR_DBGREGS_A35_3 = 0x80096000;
    // USER CONFIGURABLE
    U32 _Index_APCore = _INDEX_APB_AP_CORTEX_A;
    U32 _Addr_DBGREGS = _APB_ADDR_DBGREGS_A35_0;
    const char* _sExecCTIBaseAddr = "CORESIGHT_SetCSCTICoreBaseAddr=0x80098000";
    int ConfigTargetSettings(void) {
    // Access Port map specfication
    // Core type
    // Access Port to use
    // Specify core base address
    // Specify CTI base address
    JLINK_CORESIGHT_AddAP(0, CORESIGHT_AHB_AP);
    JLINK_CORESIGHT_AddAP(1, CORESIGHT_APB_AP);
    JLINK_CORESIGHT_AddAP(2, CORESIGHT_CUSTOM_AP);
    JLINK_CPU = CORTEX_A35;
    JLINK_CORESIGHT_IndexAPBAPToUse = _Index_APCore; // AP used as debug interface between J-Link and core to be debugged
    JLINK_CORESIGHT_CoreBaseAddr = _Addr_DBGREGS; // Specify Coresight Core Debug Register address to use.
    JLINK_ExecCommand(_sExecCTIBaseAddr); // Specify CoreSight CTI address to use.
    return 0;
