I have an application with a separate bootloader and app partitions.
If I enable RTT in the bootloader, I will not see the RTT Logs on the RTT Viewer once I jump to the app.
If I disable the RTT on the boot, then I see it in the app, but now I have no logs for the bootloader.
Is there are way to restart the RTT to allow logs to be seen on both applications? I have tried running the RTT Init at the start of each applications.
Perhaps I need to specify a fixed RAM location for the RTT ram buffer so there is continuity between the Boot and App RTT logs?
