Chip: STM32H753VI
Flasher hardware: JLink Plus
JFlash version: v6.54 (for compatibility reasons)
.bin file writes from 0x08000000 to 0x0806C580
I can flash the chip successfully by calling J-Flash from the command line.
However, I need to wipe the sector at 0x080E0000 - 0x080FFFFF which is above the last address in the .bin file.
I have tried using -delrange0x080E0000,0x080FFFFF both by itself and with the project and bin files specified.
The command seems to be ignored by JFlash.
I did also try -erasechip, which would work, except that it takes too long to be done with each device we program in production.
My question is this: does -delrange only work for ranges specified in the data (.bin, .hex, etc.) file? If this is the case, should I have
my engineers create a data file that covers the appropriate range I need to delete? Is there another way to accomplish this besides
-erasechip?
