my programm is stored at the start of flash memory at 0x8000000.
Some data should be stored in a different sector at address 0x8060000.
The Data is not flashed to the specific positon while using JLink. If i use Stlink, the data is flashed correct.
A demo programm is attached.
main.c:
char __attribute__((section (".myString"))) string[] = "String not programmed by JLink";
linker file:
STRING (rx) : ORIGIN = 0x8060000, LENGTH = 128K
.stringBlock 0x8060000 :
KEEP(*(.myString))
} > STRING
I have also tested the programm with Ozone. No data at the desired position in flash.
Bastian
