[SOLVED] Flashloader with multi flashBankInfo
  • May I know once the device been connected and includes tree flashbankinfo and tree flashloader, will all the trree flashloader been load to the ram ?
    Or just load either one at run time ?
    Ex:
    Using JLink.exe and connect MyTestDevice to execute test script as below:
    JLink.exe -device MyTestDevice -if SWD -speed 75000 -CommandFile mytest.jlink -jlinkscriptfile .\JLinkSettings.JLinkScript
    Code
    r
    h
    loadbin test1.bin 0x10000
    loadbin test2.bin 0x40000
    loadbin test3.bin 0x200000
    r
    exit
    loadbin test1.bin 0x10000 => this address mapping to FL_Test1 and will use FL_Test1.FLM
    loadbin test2.bin 0x40000 => this address mapping to FL_Test2 and will use FL_Test2.FLM
    loadbin test3.bin 0x200000 => this address mapping to FL_Test3 and will use FL_Test3.FLM
    The all loader will be loaded to ram or just load and overwrite previous one when loadbin ?
    Thanks.
    - Only one loader is loaded to RAM at a time, and
    - the RAM region used by the loader is restored after each programming sequence.
