Overwriting GUIBuilder Window Creation Callback
  • Hello
    How Can I overwrite GUIBuilder window creation callback. I want to draw a window with gradient background color.
    I tried the following modification on GUIBuilder output, but i did not work.
    (Compiler warning is included at the bottom of code)
    Thanks in advance
    the GUI_WIDGET_CREATE_INFO structure is defined as follows:
    As last parameter you passed a pointer to a callback function, where the number of extra bytes to be allocated should be. So instead of _cbWin, you can just pass 0 as last parameter.
    The WINDOW widget in your _aDialogCreate structure is not a separate window widget, it is the dialog. So, to draw a gradient you don't need another callback, you can just copy the WM_PAINT case from _cbWin0 into the _cbDialog callback.
    Florian
