[SOLVED] Jlink SDK ETM and ITM support
    I need to capture both ETM and ITM trace at the same time. If I understand correctly, if trace pins are used, both ETM and ITM data are routed to J-trace. However, in the manual of Ozone, it is state that "The simultaneous use of multiple trace data channels in Ozone is currently not supported". Here I think data channels refer to trace pins/trace buffer/swo.
    My question is, if I chose trace pins, can I get instruction trace and ITM data simultaneously in Ozone? If not, is it supported in SDK?
    Thanks!
    Correct, different data channels would be trace pins, trace buffer and SWO. Only one can be evaluated at a time.
    But ETM and ITM packets can be channeled through the trace pins at the same time. This has to be supported by the target device however.
    J-Link software will do this automatically when available for timestamp packages from the ITM.
    For other packet types you can use the SWO API from the J-Link SDK.
