[SOLVED] Remember which J-Link to use?
  • Is there a way to have SES remember which JLink to use - at least until the IDE is closed?
    Currently, if >1 JLink is connected, you have to choose which one every single time you start a debug session, or do a download.
  • Project Options, Debug > J-Link. At "Host Connection" you can choose "USB" and add the serial number of your J-Link (see the defines in the bottom of the dialog).
    Disclaimer: I did not check if it works but it seems as if it should.
  • Thanks - I'll try it out.
    This is not something that should be in the Project - it should be a User setting.
    Thinking about it, it probably shouldn't be remembered across sessions ...
