[SOLVED] Cortex M0+ Micro Trace Buffer in Ozone?
    Does the Ozone trace facility support the Micro Trace Buffer in M0+ cores?
    It does, all you need to do is select "Trace Buffer" as trace source.
    If so, will it work with an ST-Link onboard converted to J-Link STLink V21 ?
    It will, however keep in mind that the converted J-Link STLink can only be used with Ozone for evaluation purposes.
