ListWheel without entry wrap around
  • I need ListWheel not to wrap around elements. That is: above the first element, instead of showing the last element, do not draw anything. And equally under the last item should not display anything.
    Is it possible to configure ListWheel to have this behavior? Alternatively, how can I achieve such behaviour?
    best regards
    Max
    Unfrotunately, this is not possible with the LISTWHEEL widget.
    You might take a look at the SWIPELIST widget.
