I was able to establish that the GUI_FONT_13B_ASCII font is based on the TrueType Tahoma font. With Font Converter I verified the equality of about ten characters and numbers. I wonder which font the GUI_FONT_16B_ASCII is based on.
I read thist post, but I'm puzzled. I tried to convert the Tahoma Bold 13 to a standard font (not extended). I attached the c file created (with txt extension). I then made a program to display the printable characters ASCII first with the embedded font 13B and then with the one I created. I have also attached those screenshot. If you see the result it is surprisingly identical. I find it hard to think that this is a coincidence. I am more inclined to think that Segger started from Tahoma to make his 13B font. Based on this hypothesis I assumed that Segger must have followed a similar path for the 16B font. Hence my question: on which font did Segger base his 16B?
