I would like to program TI LM3S5B91 MCU but this message appear:
- ERROR: Timeout while blank checking, RAMCode did not respond in time
And FAIL the programming. Our costumer gave me the project file and the hex file also. I used the same SEGGER J-Flash programmer and the same version of the software V6.00 as our customer used, but did not working for me.
Here is the LOG:
Connecting ...
- Target interface speed: 4000 kHz (Fixed)
- VTarget = 3.316V
- Initializing CPU core (Init sequence) ...
- Initialized successfully
- CPU clock frequency: 16225 kHz (Auto detected)
- Connected successfully
Programming and verifying target (178548 bytes, 7 ranges) ...
- Start of preparing flash programming
- End of preparing flash programming
- Start of determining dirty areas in flash cache
- End of determining dirty areas
- CPU is running at 16224 kHz.
- Start of erasing sectors
- Start of blank checking
- End of blank checking
- Erasing range 0x00000000 - 0x00003FFF (016 Sectors, 16 KB)
- ERROR: Failed to blank checking.
Failed to execute RAMCode for blank check!
- Erasing range 0x00004000 - 0x00007FFF (016 Sectors, 16 KB)
- End of erasing sectors
- Start of flash programming
- End of flash programming
- 0x0000 - 0xBFFF (048 Sectors, 48 KB)
- 0xE800 - 0xF3FF (003 Sectors, 3 KB)
- 0x10000 - 0x113FF (005 Sectors, 5 KB)
- 0x13C00 - 0x2B3FF (094 Sectors, 94 KB)
- 0x38000 - 0x3F3FF (029 Sectors, 29 KB)
- 0x3FC00 - 0x3FFFF (001 Sector, 1024 Bytes)
- Start of verifying flash
- End of verifying flash
- Start of restoring
- End of restoring
- ERROR: Failed to program and verify target
Disconnecting ...
- Disconnected
Best Regards,
