I would need an explanation about the destination of the messages.
The WM_MESSAGE structure has the hWin field described as "Destination window":
C
struct WM_MESSAGE {
int MsgId; /* type of message */
WM_HWIN hWin; /* Destination window */
WM_HWIN hWinSrc; /* Source window */
union {
const void * p; /* Some messages need more info ... Pointer is declared "const" because some systems (M16C) have 4 byte const, byte 2 byte default ptrs */
int v;
GUI_COLOR Color;
} Data;
Also, the functions for sending messages (e. g. WM_SendMessage) have the hWin parameter used to indicate the target window (or at least that's what I understood).
Could you give me an example in which the hWin field of the structure and the hWin parameter of the functions are populated differently? When can such a case be useful or indispensable?
best regards
Max
