[SOLVED] RTT-Viewer escape sequnces not working
  • Hi All,
    i can't get the escape sequences in RTT-Viewer to work.
    I copied the following example from the manual into the source coe:
    SEGGER_RTT_WriteString(0,
    RTT_CTRL_RESET"Red: " \
    RTT_CTRL_TEXT_BRIGHT_RED"This text is red. " \
    RTT_CTRL_TEXT_BLACK"" \
    RTT_CTRL_BG_BRIGHT_RED"This background is red. " \
    RTT_CTRL_RESET"Normal text again."
    The text is shown in RTT-Viewer, but not in red but in standard white on black.
    It seems the escape sequences are just ignored.
    Am I anything doing wrong?
    Martin
  • AArgh, found it!
    I normally use the TAB 'All Terminals' in RTT-Viewer.
    Here the color does not change, but in the TAB 'Terminal 0' the color does change.
    Is this intentionally disabled for the TAB 'All Terminals'?
    Martin
  • Hello Martin,
    Quote
    Yes it is intentionally disabled so the user does not get confused if he uses the same colors over several channels.
  • Hi Nino,
    thanks for the explanation.
    But to be honest, I don't get the reasoning.
    How could a user be confused by showing the colors, if they are specified?
    Martin
  • Hello Martin,
    Quote
    We like to keep our software simple, what can happen is that a user uses different colorcoding over different channels (we had such use cases from customers). So when it gets mixed in one terminal
    the user cannot determine from colorcoding alone what the message means or where it comes from.
    I will suggest to our RTT dev team to have a "enable" button here for cases like yours, but no promises.
