I was working successfully with both JLinkExe and JLinkGDBServer when my target had a running SPL and U-Boot.
I just now replaced the SPL and the u-boot. u-boot is buggy, but console shows prints for SPL and U-Boot startup.
But now when I try and connect using either JLinkExe or JLinkGDBServer it fails as in dump here. Can anyone give me some hints of how to fix and get a connection again?
Kind Regards,
Owain
/git$ JLinkGDBServer -device MCIMX6S5
SEGGER J-Link GDB Server V6.10f Command Line Version
JLinkARM.dll V6.10f (DLL compiled Oct 17 2016 17:44:27)
GDBInit file: none
Terminal I/O port: 2333
Accept remote connection: yes
Generate logfile: off
Verify download: off
Init regs on start: off
Silent mode: off
Single run mode: off
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
Target device: MCIMX6S5
Target interface: JTAG
Target interface speed: 1000kHz
Target endian: little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link V9 compiled Sep 1 2016 18:29:50
Hardware: V9.30
S/N: 609300690
Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
Checking target voltage...
Target voltage: 3.29 V
Listening on TCP/IP port 2331
Connecting to target...WARNING: At least one of the connected devices is not JTAG compliant (IEEE Std 1149.1, 7.1.1.d, IR-cells). (NumDevices = 3, NumBitsSet = 2)
ERROR: Cortex-A/R (connect): Failed to temporarily halting CPU for reading CP15 registers.
ERROR: Could not connect to target.
Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
Shutting down...
Please check power, connection and settings.owain@owain-XPS-L421X:~/SVN/DSE_MDx//git$ Software/Source/u-boot-edm-imx/2013-r0/
On starting JLinkGDBServer it must be going through some JTAG stuff that results in a reset, because every time I try and start the server at the console I see...
U-Boot SPL 2013.10 (Nov 07 2016 - 11:56:46)
Boot Device: MMC
reading boot/u-boot.img
U-Boot 2013.10 (Nov 07 2016 - 11:56:46)
CPU: Freescale i.MX6SOLO rev1.2 at 792 MHz
Reset cause: POR
Board: edm_cf_imx6
DRAM: 512 MiB
NAND: 0 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Environment is in MMC....
auto-detected panel wvga-lvds
MPK: enable_lvds done
Display: wvga-lvds (800x480)
ipu_clk = 260000000
ldb_clk = 65000000
