STemwin GUI_Init Hard Fault
  • Hello. I use STemWin_Library_V1.1.2 (on EmWin 5.22). Processor STM32F103, IDE IAR EWARM 6.50. When executed GUI_Init() processor rush out in HardFault_Handler(). I found in debugging mode, what it happened when executed assembler command BLX R1 (R1=0x08004C30), or the memory address on jupm command out of processor FLASH regions. But sometimes in debugging mode GUI_Init() execute, and after GUI work OK. Change project option, stack size, GUI memory not helped. Programm still non-forking. What is the problem may be? Thank you.
    The function GUI_Init() calls the functions LCD_X_Config(), LCD_X_DisplayDriver() and GUI_X_Config(). Please make sure those functions to not cause the hard fault.
    Details can be found in the chapter "Configuration" in the emWin user manual.
    Adrian
    The display driver callback function is called with a command. Could you please tell me which one? Please note that implementing this function is user responsibility, so you will have to make sure the function works properly. For details on how to correctly modify the function LCD_X_DisplayDriver(), please refer to the section 32.6 ""Display drivers" -> "Display driver callback function" in the emWin user manual.
    Adrian
  • int LCD_X_DisplayDriver(unsigned LayerIndex, unsigned Cmd, void * pData) {
    int r;
    (void) LayerIndex;
    (void) pData;
    switch (Cmd)
    case LCD_X_INITCONTROLLER:
    _InitController();
    return 0;
    default: r = -1;
    return r;
    This function called with Cmd=1, executing _InitController(), and routine return r=0. I sure the innitialization of controller done correct.
    Edited once, last by lehacheb (June 9, 2015 at 12:50 PM).
    Are the functions LCD_X_Config() and GUI_X_Config() processed properly?
    Please note that the function LCD_X_Config() has to create an emWin display driver device and the function GUI_X_Config() needs to assign a sufficient amount of memory to emWin.
    Which driver do you use? In case you use GUIDRV_Lin, please make sure not to use the same memory area for both, GUI memory and frame buffer.
    Adrian
  • #define XSIZE_PHYS 480// Physical display size
    #define YSIZE_PHYS 272
    #define COLOR_CONVERSION GUICC_M565
    #define DISPLAY_DRIVER GUIDRV_FLEXCOLOR
    #define DISPLAY_ORIENTATION (0)
    void LCD_X_Config(void)
    GUI_DEVICE * pDevice;
    CONFIG_FLEXCOLOR Config = {0};
    GUI_PORT_API PortAPI = {0};
    pDevice = GUI_DEVICE_CreateAndLink(DISPLAY_DRIVER, COLOR_CONVERSION, 0, 0);// Set display driver and color conversion
    LCD_SetSizeEx (0, XSIZE_PHYS , YSIZE_PHYS);// Display driver configuration
    LCD_SetVSizeEx(0, VXSIZE_PHYS, VYSIZE_PHYS);
    Config.Orientation = DISPLAY_ORIENTATION;// Orientation
    GUIDRV_FlexColor_Config(pDevice, &Config);
    PortAPI.pfWrite8_A0 = Write_Cmd;//запись команда
    PortAPI.pfWrite8_A1 = Write_Data;//запись данные
    PortAPI.pfWriteM8_A1 = Write_M_Data;//запись нескольких байт данных
    PortAPI.pfReadM8_A1 = Read_M_Data;//чтение нескольких байт данных
    GUIDRV_FlexColor_SetFunc(pDevice, &PortAPI, GUIDRV_FLEXCOLOR_F66720, GUIDRV_FLEXCOLOR_M16C0B8);
    #include "GUI.h"
    #define GUI_NUMBYTES (1024) * 50 // x KByte Define the available number of bytes available for the GUI
    U32 static extMem[GUI_NUMBYTES / 4];//32 bit aligned memory area
    void GUI_X_Config(void)
    GUI_ALLOC_AssignMemory(extMem, GUI_NUMBYTES);
    GUI_SetDefaultFont(GUI_FONT_8X16);
    I use GUIDRV_FLEXCOLOR
    According to the emWin user manual the function pointer PortAPI.pfRead8_A1 should be set. For details, please refer to section 32.7.4 "Display drivers" -> "Detailed display driver descriptions" -> "GUIDRV_FlexColor".
    Adrian
  • I added function PortAPI.pfRead8_A1. No changes. In emWin user manual PortAPI.pfRead8_A1 need for GUIDRV_FLEXCOLOR_F66721 (I am GUIDRV_FLEXCOLOR_F66720). By help debugger I find what GUI_Init() not use
    Please note that the statement is wrong in the emWin user manual. The additional function to implement for the 66721 mode is pfReadXX_A0(). Either way the pfReadXX_A1() needs to be implemented.
    The emWin user manual will be corrected accordingly.
    Adrian
    I am afraid I do not have further suggestions. I would recommend you to contact ST for support. Maybe they can help you better. From my point of view this problem is not caused directly by emWin.
    Adrian
    I've got the same issue. X(
    I notice that the "Hard Fault" trap disapear if i use only one layer.
    I use TFT4.3" and a 16bits external sdram on my board vs the 32bits sdram on the STM32F429i-EVAL.
    Do you have more idea to solve our problem ?
    Best regards.
    Olivier
  • Lehacheb, i think you should use functions
    PortAPI.pfWrite16_A0 = LcdWriteReg;
    PortAPI.pfWrite16_A1 = LcdWriteData;
    PortAPI.pfWriteM16_A1 = LcdWriteDataMultiple;
    PortAPI.pfReadM16_A1 = LcdReadDataMultiple;
    I understand correctly you have 16 bits data bus?
    Edited once, last by pvo125 (September 15, 2015 at 8:37 AM).
  • I have 8 bit data bus. Но это вроде бы как неважно, сами-то функции описаны правильно, потому что иногда инициализацию проходит и GUI загружает. Но все равно скинь пожалуйста, посмотрю
  • My functions in file LCDConf.c
    static __INLINE void LcdWriteReg(U16 Data) {
    // ... TBD by user
    LCD_REG_ADDRESS=Data;
    static __INLINE void LcdWriteData(U16 Data) {
    // ... TBD by user
    LCD_DATA_ADDRESS=Data;
    static __INLINE void LcdWriteDataMultiple(U16 * pData, int NumItems) {
    while (NumItems--) {
    // ... TBD by user
    LCD_DATA_ADDRESS = *pData++;
    static __INLINE void LcdReadDataMultiple(U16 * pData, int NumItems) {
    // ... TBD by user
    *pData++ = LCD_DATA_ADDRESS;
    void LCD_X_Config(void) {
    // U32 TouchOrientation;
    pDevice = GUI_DEVICE_CreateAndLink(GUIDRV_FLEXCOLOR, GUICC_M565, 0, 0);
    // Display driver configuration, required for Lin-driver
    Config.Orientation =GUI_MIRROR_Y|GUI_MIRROR_X;
    //Config.FirstCOM=0;
    //Config.FirstSEG=0;
    // Set controller and operation mode
    GUIDRV_FlexColor_SetReadFunc66720_B16(pDevice, GUIDRV_FLEXCOLOR_READ_FUNC_II); //GUIDRV_FLEXCOLOR_READ_FUNC_II
    GUIDRV_FlexColor_SetFunc(pDevice, &PortAPI, GUIDRV_FLEXCOLOR_F66720, GUIDRV_FLEXCOLOR_M16C0B16);
    My version LCD_X_Config not much different from yours. You hardfault happens at what point (LCD_X_Config, LCD_X_DisplayDriver or in the wilds of the library in the disassembler?)
    Edited once, last by pvo125 (September 15, 2015 at 8:38 AM).
