J-Flash and AT91SAM9620-EK
    I’m trying to use J-Flash (version 3.80b and beta 3.81f) with a SAM-ICE probe together with an AT91SAM9260-EK. When I open the project file “AT91SAM9260_CFI_1x16.jflash” that is installed under samples and try to connect I get the following error messages:
    Bad JTAG connection: Write to IR: Expected 0x1, got 0xf (TAP Command : 15) @ Off 0x19FD
    Bad JTAG connection: Write to IR: Expected 0x1, got 0xf (TAP Command : 15) @ Off 0x5
    And after OK:
    Could not find supported CPU core on JTAG chain. Failed to connect.
    J-Link seems to recognize the core and gives me the following output. Also I’m able to read and write SDRAM content.
    SEGGER J-Link Commander V3.81f ('?' for help)
    Compiled Apr 2 2008 19:17:37
    DLL version V3.81f, compiled Apr 2 2008 19:17:25
    Firmware: J-Link compiled Mar 3 2008 19:52:16 ARM Rev.5
    Hardware: V5.20
    S/N : 20001090
    OEM : SAM-ICE
    Feature(s) : RDI
    VTarget = 3.280V
    JTAG speed: 5 kHz
    Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ
    Info: CP15.0.1: 0x1D112112: ICache: 8kB (4*64*32), DCache: 8kB (4*64*32)
    Id of device #0: 0x0792603F
    Found ARM with core Id 0x0792603F (ARM9)
    J-Link>speed auto
    Info: RTCK seems to be bridged with TCK
    Info: Auto JTAG speed: 8000 kHz
    I tried to adapt the project settings (in a way that helped in other forum entries) but without success. Am I doing something wrong?
    Cheers,
    Uwe
    ps: Here is the log output of JFlash:
    Application log started
    - J-Flash ARM V3.81f (J-Flash compiled Apr 2 2008 19:17:59)
    - JLinkARM.dll V3.81f (DLL compiled Apr 2 2008 19:17:25)
    Reading flash device list [C:\Program Files\SEGGER\JLinkARM_V381f\ETC\JFlash\Flash.csv] ...
    - List of flash devices read successfully (495 Devices)
    Reading MCU device list [C:\Program Files\SEGGER\JLinkARM_V381f\ETC\JFlash\MCU.csv] ...
    - List of MCU devices read successfully (236 Devices)
    Opening project file [C:\Program Files\SEGGER\JLinkARM_V381f\Samples\JFlash\ProjectFiles\AT91SAM9260_CFI_1x16.jflash] ...
    - Project opened successfully
    Connecting ...
    - J-Link firmware: V1.20 (J-Link compiled Mar 3 2008 19:52:16 ARM Rev.5)
    - Using adaptive clocking instead of fixed JTAG speed
    - Initializing CPU core (Init sequence) ...
    - ERROR: Failed to connect
  • Hi Tobias,
    thanks for the info.
    No, the At91SAM9260-EK starterkit is just equipped with 256 Mbyte NAND flash and a serial data flash, so both should not work with J-Flash. Is it planned to support NAND flash as well in future versions?
    Cheers,
    Uwe
