AppWizard Set PROGBAR COLOR
    • AppWizard Set PROGBAR COLOR
      ppWizard V154a_646a ,
      C CODE
      if(LD>50)APPW_SetVarData(ID_VAR_BAT_COLOR,GREEN); //0X07E0
      else if(LD>20)APPW_SetVarData(ID_VAR_BAT_COLOR, GRED); //0XFFE0
      else if(LD<=20)APPW_SetVarData(ID_VAR_BAT_COLOR,GRED); //0XFFE0
      //PROGBAR0-26 , LD 0-100
      APPW_SetVarData(ID_VAR_BAT_PROGBAR,LD/4+1);
      The actual running effect is displayed in black regardless of the variable value set;
      Is the usage incorrect?
      The post was edited 2 times, last by CF_238001 ().
      seems there's nothing wrong with your code, I'm using AppWizard V154_646 and it works fine on my side.
      1. void ID_SCREEN_00__APPW_NOTIFICATION_INITDIALOG(APPW_ACTION_ITEM * pAction, WM_HWIN hScreen, WM_MESSAGE * pMsg, int * pResult) {
      2. GUI_USE_PARA(pAction);
      3. GUI_USE_PARA(hScreen);
      4. GUI_USE_PARA(pMsg);
      5. GUI_USE_PARA(pResult);
      6. APPW_SetVarData(ID_VAR_COL, GUI_GREEN);
      7. }
      Maybe you should check if you set a color within the properties of the progbar in AppWizard does this shows correct color without adding C-code.
      Anthony
