Programming Custom nRF5340 PCB via J-Link Interface defies laws of physics?
    • Programming Custom nRF5340 PCB via J-Link Interface defies laws of physics?
      Hi, I am seeking assistance with a very weird issue encountered while programming an nRF5340 SoC using a custom debugging-PCB using a SEGGER J-Link EDU debugger.
      The debugging PCB is designed to plug directly into the J-Link (and the board featuring the nRF5340 plugs into this board).
      The nRF appears in VS Coder under connected devices, but attempts to flash the device result in the following error:
      1. [error] [ Client] - Encountered error -102: Command program_file executed for 755 milliseconds with result -102
      2. [error] [ nRF53] - The write access failed, but no cause could be determined.
      3. [error] [ nRF53] - It may be due to an unaligned access, accessing a nonexistent memory, or a communication issue.
      4. [error] [ nRF53] - Failed while performing 'Write' operation on target address 0x01000000.
      5. -102: An unknown error.
      6. [error] [ nRF53] - Failed while reading device information.
      7. [error] [ Worker] - An unknown error.
      8. ERROR: JLinkARM DLL reported an error. Try again. If error condition
      9. ERROR: persists, run the same command again with argument --log, contact Nordic
      10. ERROR: Semiconductor and provide the generated log.log file to them.
      11. NOTE: For additional output, try running again with logging enabled (--log).
      12. NOTE: Any generated log error messages will be displayed.
      13. FATAL ERROR: command exited with status 33: nrfjprog --program /Users/philipp/TECO/open-earable-v2/build_1/merged_CPUNET.hex --sectorerase --verify -f NRF53 --coprocessor CP_NETWORK --snr 260115464
      HOWEVER, when the debugging PCB is not plugged directly into the J-Link, but each pin is individually connected to the J-Link using jumper wires, programming proceeds without issues.
      I've narrowed down the issue to the SWCLK line: connecting the debugging PCB directly and soldering a 5 cm jumper wire between the SWCLK pins solves the issue.
      This doesn't work:
      This does work:
      This doesn't work again:
      Troubleshooting Steps Undertaken:
      1. Measured the resistance of the connecting cable, which is approximately 0.5 Ω
      2. Introduced resistors ranging from 0.5 ohms to 200 Ω in series with each J-Link pin (especially SWCLK to simulate the jumper wire resistance); this did not resolve the issue.
      3. I noticed that probing the SWCLK line with an oscilloscope prevents successful flashing, indicating sensitivity on this line.
      4. Implemented external pull-up and pull-down resistors for SWDIO and SWCLK, as well as low-pass filters, without achieving successful programming.
      5. Built an "extension" plug that plugs directly into the J-Link and then in the debugging PCB, then it doesn't work. If the debugging board is not entirely plugged in all the way (leaving some millimetres while ensuring all lines are connected, it works....
      6. I've tried different programmers to no avail, but we only have EDU programmers because I'm working at a university. JLink shows VTref=1.812V, both on the older debugging PCB that works, and on the new PCB design that doesn't work. I also tried J-Link EDU Mini V2 with jumper wires, here the debugging PCB doesn't work either, whereas with the "normal" J-Link EDU it works with the exact same cables etc.
      When probing the lines with an oscilloscope, you can see a bit of ringing, butthe signal is the same if probed with jumper wire extensions or without, so this can't be the issue, right?
      TLDR: I'm literally clueless at this point. All my colleagues have looked over the schematics, we ruled out any issues we've come up with, it just doesn't work, when there's a direct connection, it works when there a jumper wire in the SWCLK line
      I appreciate any insights or recommendations from the community to resolve this weird bug
      The post was edited 1 time, last by lepold ().
