Jlink mini EDU assistance
    • Jlink mini EDU assistance
      I am an electronics hobbyist and am currently building a robot and I would like to incorporate a radar sensor that needs to have the firmware flashed. There is a pdf with instructions how to do this, and I am trying to use my JLINK mini EDU that I have from many years ago. I followed the instructions and used uVision (1st time using it) to attempt to flash it. It finds the Jlink, but it does not find the radar module, which apparently has a GD32E230K8 microcontroller chip. I tried all 4 versions of the chip shown in the menu. I can send screenshots and all information related to this project, I'll attach some here. I'd really appreciate if there is someone that can assist me in this endeavor.
      The instructions are found in the document: RD-03E english manual on pages 4-8.
      When I select Erase or Download from the Flash menu I get the following output:
      Brainfuck Source Code
      1. Set JLink Project File to "C:\Users\perigalacticon\OneDrive\Documents\uVision\JLinkSettings.ini"
      2. * JLink Info: Device "GD32E230K8T6" selected.
      3. JLink info:
      4. ------------
      5. DLL: V8.12f, compiled Feb 12 2025 13:34:40
      6. Firmware: J-Link EDU Mini V1 compiled Mar 16 2017 12:04:38
      7. Hardware: V1.00
      8. S/N : 801001385
      9. Feature(s) : GDB, FlashBP
      10. * JLink Info: InitTarget() start
      11. * JLink Info: Error: Failed to initialized DAP.
      12. * JLink Info: InitTarget() end - Took 3.55ms
      13. * JLink Info: Connect failed. Resetting via Reset pin and trying again.
      14. * JLink Info: InitTarget() start
      15. * JLink Info: Error: Failed to initialized DAP.
      16. * JLink Info: InitTarget() end - Took 3.35ms
      17. Error: Flash Erase failed - Target DLL has been cancelled
      18. Flash Erase finished 16:58:04
