JLinkGUIServerExe takes 100% CPU
    • JLinkGUIServerExe takes 100% CPU
      New
      Hi!
      I'm using Ozone 3.38c with a J-Link Pro under Arch Linux, installed from AUR.
      Since a few versions, I noticed that Ozone starts one or more JLinkGUIServerExe processes that take 100% CPU after a short while.
      What is the purpose of this process?
      The post was edited 2 times, last by thomask77 ().
    • New
      As a workaround, the processes can be killed with killall JLinkGUIServerExe.
      Another workaround is to simply rename the JLinkGUIServerExe file:
      sudo mv /opt/SEGGER/JLinkGUIServerExe{,_bak}
      Surprisingly, this does not have any effect on the Ozone session..
      The post was edited 1 time, last by thomask77 ().
    • New
      The problem can also be reproduced using telnet:
      Good case:
      $ /opt/SEGGER/JLinkGUIServerExe &
      $ telnet 127.0.0.1 19022
      Trying 127.0.0.1...
      Connected to 127.0.0.1.
      Escape character is '^]'.
      J-Link GUI server;V8.12b;
      Bad case:
      <<< WAIT 10 seconds >>>
      Trying 127.0.0.1...
      Connection closed by foreign host.
      -> JLinkGUIServerExe now takes 100% CPU.
    • New
      I'll attach an strace log:
      strace -o trace.txt -f /opt/SEGGER/JLink/JLinkGUIServerExe
      showing a
      * succesful open and close of a telnet connection (line 2545 ..)
      * 10s wait (line 2665 ..)
      .. it then seems to close the server socket in line 2765
      * a failed telnet connection
      server is now stuck in a 100% CPU loop while calling pselect6 for the already closed server socket.
      trace.txt
      The post was edited 3 times, last by thomask77 ().
    • New
      The JLinkGUIServer is generally responsible for hosting GUI pop-ups to interact with the J-Link, such as warnings, errors, or dialogs for inputting authentication when the target is protected.
      We are aware of the issue you reported and have already implemented a fix. The fix will be included in the next version, scheduled for release in the middle of next week.
      Simon
