S32K344 J-Trace Unexpected core ID
    • S32K344 J-Trace Unexpected core ID
      I am using J-Trace Pro Cortex-M debugger with a S32K344, the problem is that I get an Unexpected core ID when connecting over JTAG to the MCU with J-Flash. However the issue does not occur when I connect over SWD.
      The same issue happens when using MDK Keil(JTAG - doesn't work, SWD - works)
      When using Ozone for debugging everything works fine, I can use trace, and don't get any errors or warning regarding Core ID.
      I see that someone encountered the same issue with S32Kxxx MCU, but no solution for this problem was found there.
      Did anybody encounter such an issue and maybe knows the solution ? Thanks!
